6500 mAh battery.
135 x 44 x 29
11.1v 30C
Brand ZOP Power
from banggood.com
Weight not sure but less than OEM Yuneec battery.
Best of luck.
Chroma Pilot,
The Chroma uses a 3S battery, the Typhoon H uses a 4S battery. So your sample won’t work for an H.
But there is good news. The process that will be used for the Typhoon H is also applicable to the Chroma. The first battery case I split to experiment with was a Chroma battery and although it’s a 3S the manner in which it is assembled is pretty much identical with a Typhoon H, but with less wires and battery cells. The reason I started with a Chroma battery is because I gave my Chroma to my grandkids and those batteries can’t be found either.
So hang tight and wait for the battery adaptation thread. You might find it useful.
