Problem with the controller for the H520 drone
I have a H520 drone and a software problem on ST16. There is only partial software (no gimbal calibration and other features). Below are the pictures. It supposedly shows the correct files when updating and that there is the latest version but it's like only half of it. What is the problem?
"...no gimbal calibration..."
None of your images showed the pages that would contain the controller gimbal calibration. Try this:
"...and other features"
Your images seem very similar to mine. It is hard to tell what is normal without knowing which controller firmware version by version ID you have, where you obtained the controller firmware, and if any aftermarket APPS have been added. Once we know that, and specifically which items you are missing, we can make more accurate comments.
If you press and hold the center button below the screen, the controller will take a screenshot. You can then transfer the screenshot using SD card or USB as an easier way to get images to post. The screenshots are in file manager, under the "pictures" folder.
The green progress bar for connecting the drone stops after a while, then moves a little and stops again. There are various messages along the way until it finally reaches the end. There is a camera control only the arrow (the yellow kind) showing where the “camera is looking” works with a long delay.
The camera itself (CGOET) seems to work correctly.
After calibration, everything seems to work correctly, only the potentiometers K1, K2, K3 show different values (they don't go to 0), should this be the case?
In addition, apparently there was some kind of update done here and it is not clear where the files were downloaded from.
Theoretically everything is green - also after updating the files there is no gps, gyro, gimbal calibration option in the menu.
Probably a version incompatibility. Security settings are also missing (as if half the settings are missing) :(
and another 5 images
I am about to leave for another city and will not be available until much later today. But a couple of quick thoughts:
1.) Do you have an e90 you can substitute to see if the issues are from the camera instead of the controller?
2.) The file system has a suspicious version of Typhoon H firmware on it. That leads to thoughts the controller may have been incorrectly converted from either an original ST16 (visible screw holes around the controller gimbals) or maybe even from an ST16E (requires opening the case to see if it has an ODFM module or an SR24). ALL versions say just "ST16" on the face of the controller.
3.) The updater APP was downloaded from APKPure. There is nothing really wrong with that, other than it is another hint this was not an OEM ST16S for H520.
4.) The K1,K2 and K3 issue implies the three controllers were not in the exact center prior to leaving the first stage of the calibration. Try the calibration again, ensuring the controllers are centered. If the issue persists we can address further.
5..) The transmitter version and radio version will not display unless you press the "READ" button associated with each. If either still fails to display, it implies an incomplete or bad firmware load.
6.) Some of you words seem to mean someone else did the update. Please tell us as much as you know of the history of the controller between the last time it worked properly and the first time it did not. If you don't know the history, describe the condition of the controller when you got it.
Reactions: DoomMeister
Unfortunately I was only able to borrow an E50 camera (that's the only one a friend had) but unfortunately it's the same, maybe it loads a little faster but still the green progress bar stops 3 times, the problem with the arrow on the right still when the camera is down after about 5 seconds it just goes down, the problem with the K1,K2,K3 controller still exists despite setting the potentiometers in the middle in short nothing has changed and I guess you have to reinstall the files in the controller. I am uploading some more screen shots.
First thought:
In your first post you said "Theoretically everything is green - also after updating the files there is no gps, gyro, gimbal calibration option in the menu.". I think I mistook your meaning. Did you mean these items are missing on your controller?
@DoomMeister sent me a PM mentioning that CGoET and E50 may not be compatible with the H520 Update process, that only e90 works. I do not know, so I did a factory reset and re-ran UpdatePilot with the drone turned off. This changed the screens to something similar to what you describe. Is this what you see?
When the e90 (and H520) was bound, the screen returned to the normal array, all items present, with no additional actions needed.
This "First thought" should be extended to include the possibility the ST16S 5.8Ghz receiver is just not functioning properly.
If the "First thought" does not seem to reflect the issue:
We still don't have much history on the controller and the previous updates. The chief worry/distraction about the physical controller is that it may actually be an ST16E. If you don't know the full history of the controller, you can compare these features to confirm the controller's physical model:
It would be useful to know if a factory reset performed prior to update? (Some of the existing contents of file manager suggest it was not.)
When you did the manual controller calibration earlier, did you ensure the controller could read both transmitter and radio versions?
When you mentioned "There is a camera control only the arrow (the yellow kind) showing where the “camera is looking" works with a long delay." did you mean this one?
When you mentioned "The camera itself (CGOET) seems to work correctly." did you mean the camera pitch(tilt) moves normally and only the yellow arrow shows a time lag?
You have mentioned the "green progress bar" a couple of times. Please confirm you mean the thin green bar that runs across the top of the screen as the camera is connecting.
Does the bar disappear when the image appears on-screen?
Controller is ST16S
No tabs for RC Mode, Sensors, Safety, Gimbal, Accessories
This is exactly how I see it
Factory reset was rather absent
This is how it can read the version of the transmitter and radio
Yes this one - marked with your arrow
Yes the green bar disappears when the image appears
The path is not clear due to me not having CGOet or E50 to experiment, and you not having an e90 to experiment. Without those or someone else helping the discussion, it is a guess whether the issue is camera, firmware or hardware. I did mount and manually bind a C23. The result was the same limited displays and menu buttons as you are seeing with the CGOet and the E50.
Regardless of whether this is camera mismatch, firmware problem or hardware problem, the controller should eventually get a factory reset and a clean load of only the required files. Be sure you have a new copy of the updaterapp.apk on an SD card to facilitate the reload.
I've been told the e50 should work normally and that the correct version of CGoET will work normally. The member was unable to either validate or dispute the observation related to a manually bound C23, but even so, I see this news as an encouragement to pursue the hardware or firmware possibilities. The firmware factory reset would be a good first step since it has the added benefit of cleaning up the controller.
Unfortunately but reinstalling did not help anything. It is still the same i.e. the top bar after switching on and after connecting to the camera (there is a control) stops at 50%, 75% and 95%. At the very beginning a yellow screen popped up and only by restarting the controller did it disappear and now it turns on ‘normally’. Unfortunately, you have to manually bind the drone with the camera every time. The yellow screen with the DataPilot information shows up.
Still the camera position indicator works with a big delay (after about 10 seconds it shows the right position) and still no full MENU.
Did you try using your controller and your camera on your friends drone to see if there is an issue with the drone?
I ask because the message about "the full parameter list" could also be a drone problem. Possibly something as simple as a poor connector in the circuit.
Or outdated firmware. Your image shows the drone firmware as 1.7.119. I think at least one later version exists, but I do not know the current official latest version, or even which versions fully support the required parameters. Hopefully @Enrico Jorysch or someone else might know.
Your friend's working H520 may also be a reasonable reference.
Note: updated to remove erroneous reference to H520E.
The latest firmware for flight control:
H520: v1.9.0-1.7.119
H520E: v1.9.0-1.7.156
H600: v1.9.0-1.9.112
H850: v1.9.0-1.9.102
Reactions: WTFDproject
I have a H520 drone and a software problem on ST16.......
How long have you had the drone, camera, controller?
Was the system working properly when it came into your possession?
If so, what changed between the last time it worked properly and the first time it did not? Things like crash, hard landing, modifications, repairs, firmware updates, calibrations, aftermarket app installation or anything else you can think of that may be related to the issue.
I rented an H520 drone with an E90 camera from a friend. After connecting his controller to my drone there is the whole MENU, when I connect my controller to his there is still no MENU, so the problem is clearly with this particular controller.
As far as his history is concerned, supposedly the drone was lying in a cupboard for a year and then he updated it, he doesn't know where but supposedly also on the US sites but surely that wasn't the case as he was surely up to something else. The question is how to restore the full MENU since restoring to factory settings and then installing from the indicated downloaded file (updaterapp.apk) did not work?
I wish no updates had been performed. It would have allowed a much better picture of what you are dealing with. But that is just wishing. Where we are is where we are.
It could be a hardware problem with the controller antennas. Or it could be the 5.8Ghz module in the controller. It could be a failed board component. It could be a glitch in the way the controller handles the update process.
The next step would be to find a service center that can either find and replace the bad components or boot load the controller all the way back to the original Typhoon H ST16 firmware, then do the conversion process up to the H520 ST16S that it really is. And I have no way of knowing if even that would work.
At this point, the cost of buying random parts or paying a repair facility may outweigh the cost of a replacement controller.
Write your reply...
osttopstconverter
