Recording flight way points to re-fly later
Colorado
I'm sure someone has asked this question but i haven't found it.
Is there a way to record way points while flying along with camera operations/gimbal positions to re-fly later as a mission?
I have tried looking at the Telemetry Logs but every way i have found to convert them does not put them in a format that Data Pilot will use as a mission
Thanks in advance for any help
No, this function does not exist for the H520. It exists at another manufacturer, but not there.
There is the vanguard and there is the stone age. It's necessary to choose.
I did no know that the Yuneed Typhoon H20 or the Typhoon H+ did not have CCC (Curved Cable Cam) mode.
Just check whether your Typhoon has or does not have CCC mode. If so, it I jut as you described in that you record and it flys a pre-recorded set of Way Points. It IS NOT Telementry Logs that you are looking for, Have fun.
The H Plus does have CCC. I have used it a few times on mine.
marc13690
