Hello guys,
I misplaced my serial number stickers, is there another was to check from #SN numbers?
For the aircraft? It is on the starboard side of the body just above the gimbal and starts like - S/N:YU___ followed by numbers.
Another way is; go into your FAA login, where you register your aircraft under your 107, it will be there. I am pretty sure I remember seeing my other H listed when I registered my Plus recently.
Where did you purchase the system? I purchased mine at Best Buy and the sales receipt has the main S/N on the receipt. And, of course, the cardboard sleeve that was around the H+ backpack has the S/N printed on it, if you still have that...Hello guys,
but always take pictures with the labels stuck on the drone, especially for work insuranceBig grind!!! I got directly from Yuneec and it’s on my packing slip. FOUND IT!
