Should I be calibrating my camera at start of every flight?
I've noticed that, at certain angles, the horizon is almost always slightly off. Should I be calibrating A LOT more often?
As you slowly yaw the aircraft with the camera in the up position, do you see the horizon angle changing? To check it the horizon needs to be in the center of the screen.
Rank Li
