strange noise
hello it s me
I discovered a noise when I turn the propeller placed on the engine. I thought has a driving problem but j replaced this propeller by a new one and more of cloc. I invite you has to verify this place to avoid a wear engine and vibrations
Reactions: Kendrone
Since you did not answer my second question I have to options:
Turned On: The sound is likely to be perfectly normal (not very loud electronical buzzing sound). This is the motor break which improves the response of the motors during flight.
Turned Off: It is likely that you have a problem. If it sounds like something is scratching you might have dirt inside the motor. If it sounds like a rattling noise at least one of the bearings is worn down.
I use the originals yuneec propellers and in fact a premature wear causing a game and a light noise. It is absolutely necessary to replace them not to tire engines
ThatsOneFriendlyMofo
