I have the same problem. (US Version) - Have to pull the battery to get it to turn off.
I do have access to the Camera. Will try the GUI to put it back to V1.28
Seemed to have crashed in Step 2. Was able to upgrade the Camera via wifi on try 2 but auto pilot is bricked
You managed to restore TH ?Well my H is Bricked so bad that the Board is not detectable as a USB device :/
they sent me a xxxxx.yuneec file as firmware to erase the Typhoon H (With GUI)
No luck
Got a RMA Tag Prepaid and off to Cali it goes. Took 2 phone calls.
i don't think some pilots don't understand. if the h does not see the camera you can not bind it, the camera does not report back to the h like its not thereYou probably just need to bind to the camera again.
that's what happen to mine, its dead, its at the yuneec repair center as we speakabsolutely nothing happens !!! how to solve a problem...
Same here, done the b.27 updaye. ST16 fine but typhoon is n ow 'invisible' to ST apart from camera.
Get one quiet beep on startup no lights on arms and cannot turn it off with the power button.
Brand new out of the box, well impressed NOT...
What is this 'programmer' and GUI software that Mr Steve carr mentions a few posts above this one?
I believe you can change the altitude cap in the GUI...No mine bricked so bad they sent me a RA tag
arrives in Cali Monday, Im not too thrilled the 3.0 firmware caps us at 400 ft
as I can fly Higher at my AMA field than 400 ft
I'm really considering selling The Typhoon H and going with the DJI 4 Pro or Mavic
is this accurate??Im not too thrilled the 3.0 firmware caps us at 400 ft
c
Seems the last update added a bug. They say it will be fixed in the next update.is this accurate??
is this accurate??
