Tilt slider st16s
Top right corner were your apps are there should a android called flight controller, i had same problem you can calibrate from there.
Yes thanks to georgero visual instructions I finally found where the calibration menu is. Thanks for your reply.
There is a way to calibrate your controller without doing a factory reset. Follow the pictures below and you will get there really easy. Do not touch anything else in less you are a professional and you know what you do. That is a warning.
P.S. When you do the calibration make sure the tilt and the speed knobs are in the middle position before you start the calibration.
Thank you very much
jonnyelectric
