I'm reaching out to you knowledgeable guys to find out if there is a way to re-calibrate the tilt control slider on the st16s. Here is the issue. After unpacking and inspecting aircraft and controller, after batts were charged, I took here on her maiden flight and noticed the camera would not come to level after powering up. I searched through the forums and noticed there is no gimbal calibration on the H+, that I could find. So I bring up the monitor for the controller and I see the slider will only go halfway and no further. Is there a way to correct this ( other than replacing the slide control)?
