WIFI Connection dropping
Hi all
New Typhoon H owner here, my Copter is loosing WIFI (Camera) connection around 3 mins into every flight.
To resolve it I have to open “System Settings” and refresh the bind screen, highlight the CG03+ and head back to the home screen.
Using the Raptor SR range extender on the ST16
Mid flight image attached
If I am correct you have an antenna mod done right? Has it been done correctly? Please double check if all the conections are connected to the right ports and make sure they are not damaged and properly secured. Even without/with wrong antenna connection ist possible although only for a very limited range.
In case everyhting is connected properly you might want to check the camera. Has it been involved in a crash before? Does the heat sink get warm? A little bit is normal but if it gets very warm or even hot it might be a problem. Also make sure the fan is running. You should be able to hear it.
frankesjames
