Wizard and ST16
Hi All
Once you have synched, bound and done everything correctly with the wizard and you then want to fly with the ST16, do you have to bind the ST16 again and subsequently each time thereafter when flying with one or the other?
Yes, this is 1:1 connection, means you can have bound only one controller to the copter (as well as only one copter to the controller).
If you change, you have to bind again, either wizard or ST16.
Don't forget to bind the ST16 to your bird again if you have used the wizard before. Since the feature "Dual Band Control Redundancy" is in, you can control the copter via WLAN without having the 2.4GHz connection. Due to WLAN latency there may appear strange behaviour during the flight and landing may be hard to control. Some people lost props because of this...
Axel66
