Yuneec Q500 with the CGo2 camera attached but removeable
It has video but, I am getting warning light and sound beep beep beepbeepbeep , controlller wont move the camera up or down
The camera and the gimbal are built into one unit for convenience, but they are two different things. You have a gimbal problem. Specifically, the Yaw encoder has a problem.
This would normally be a shop repair but it may be difficult to find a shop that can do the repair.
Did anything happen to the gimbal between the last time it worked and the first time it did not? Things like crash, long storage time, firmware updates, repairs, modifications or anything you can thing of?
You can also check that the connector marked "K" in the attached image is not loose or has wire damage.
View attachment 32323 yea I looked for damage on wires but there is nothing pluged in the socket for K
No damage
There should be black wires coming out from the center with a white plug on the end. If you can find it and plug it back in, the gimbal may work again.
  • Sad
barkercollege
