- Joined
- May 18, 2025
- Messages
- 10
- Reaction score
- 0
- Age
- 68
It has video but, I am getting warning light and sound beep beep beepbeepbeep , controlller wont move the camera up or down
No damageThe camera and the gimbal are built into one unit for convenience, but they are two different things. You have a gimbal problem. Specifically, the Yaw encoder has a problem.
This would normally be a shop repair but it may be difficult to find a shop that can do the repair.
Did anything happen to the gimbal between the last time it worked and the first time it did not? Things like crash, long storage time, firmware updates, repairs, modifications or anything you can thing of?
You can also check that the connector marked "K" in the attached image is not loose or has wire damage.
View attachment 32323 yea I looked for damage on wires but there is nothing pluged in the socket for K
It looks that way. They went dark a couple of months ago.Is vertigo also gone?
there is nothing plugged in the k socket no wiresNo damage
Can you see under the gimbal board with a flashlight to see if a blue box is visible under the center of the board?there is nothing plugged in the k socket no wires
ok led under the board is flashing red and 3 beeps I also put the camera in the steady grip on an angle while booting up and theNo damage
yesCan you see under the gimbal board with a flashlight to see if a blue box is visible under the center of the board?
The blue/red/green suggests there are other issues as well.led is flashing blue red green
