Breeze goes up when pressing home
First time using Breeze I pressed the home button to land it and instead it took off going straight up, crashed into the ceiling of my shop and landed on a leg and broke a prop. Any ideas why it would go straight up instead of landing when pressing “home”?
Any time you press the home button there is a preset altitude, this is in order if you wanting it to come home being outside so to clear any obstacles. I'm not sure what your instructions say, but this is why first fly outside.
Open Breeze Cam, press the burger on upper left, open drone settings, slide from right to left until you get to Height Return Home setting. That is the height the Breeze will climb to when you initiate Return to Home.
MarkIII
