CGO2 GB on Typhoon H
This is my first post on this forum so if im in the wrong place just let me know.
I'm currently trying to wire a CGO GB to my recently purchased used Typhoon H.
There is a single plug coming out from under the bird that connects to a slide connection for the CGO3 I believe. How do I connect that to my CGO2?
Anyone that can help will be greatly appreciated.
I don't know if CGO2 works but I used CGO3 with success on Typhoon H. You need an adapter from the 5-wire cable inside the TH to the 3-wire cable on the CGO cam.
You need GND (ground), VBAT (+) and PWM (pulse wide modulated signal for camera tilt). RX/TX is not supported by CGO2/3, thus tasks like Orbit, POI will not work anymore.
CGO pins:
TH pins:
I'm not sure if the CGO2 can deal with the higher voltage coming from 4S batt in TH. The CGO3 can do.
If smoke comes out, the CGO2 cannot ;-)
Thanks for the reply! The CGO2 runs off of 12v or 3s. Yeah I need to figure out which port to plug into the cgo2 with which wires.
soldier08
