CGO3+ breakdown
ordered an internal antenna for the CGO3+ anyone have a breakdown or a walkthrough of how to replace it? I also ordered an antenna for the ST16 and replaced it, but the problem is still there. No connection or weak connection from the bird to the controller. If I get a connection then it stops transmitting 100-300ft out
If you have a phone or tablet that is 5GHz enabled, then you can turn on just the H and see if the CGO3 shows on the the list of available wifi's. If it's there you can connect to it using the password and then open the CGO3 app. Check to see how far the signal works before dropping out. Of course it will be much shorter than the ST16 but we can compare it and see if the problem is in the camera or the controller.
Sierrarhodesss
