I would start by putting it back on the GUI, running the motor test, and see which motor/esc is causing the problem. Sounds like you are getting pretty close to flying again.
When I tested the drone I did not have the prop blades on. Would this cause the warning I got.
. I tried to reset and the ST 10 screen did not come on and I did not hear the normal android sound when it turns on.
Alligators, where was this?SUCCESS!!!! I tested my drone this morning and it preformed perfectly. I did as you suggested and flew if just off the ground without the camera. Then I flew it again with the camera and recorded some video. I will run another low flight test before going higher to be sure nothing else will show up as a problem. I can't believe I got this going again. From the rescue of the drone a few weeks ago where it was hanging 3" above the water in a tree limb surrounded by seven alligators, to trouble shooting and repair. If it was not for you this would never have happened. I thank you and appreciate all of your help and the parts you sent me. This is a good day. Thanks again, John
Yup. Even close enough for a drive. You guys might want to PM a meet sometime.Alligators, where was this?
John,
This is great news. But please don't push it too far right now. I don't like the issue about the blue LED. I am heavy into another issue right now, and have not looked into your blue LED, but it suggests something is not quite right about that ESC. I promise I will get to it as quickly as I can. Those 'gators are pretty mad they missed out the first time. They aren't going to let it get away again.
I feel better about it now.
Yes it is the front ESC you sent. Maybe I should change it. The (back motor) small orange /yellow wire with connectors was the one I pinched. I would replace it but it is not sold separately, only with the flight controller. I think I might order a new ESC along with a new light. What do you think?Is the front left ESC the one I sent?
You also mentioned pinching an ESC wire a little bit during assembly. Was that on the left front?
