I sure will. Thank youCall Yuneec and explain this to them. Take a couple of still pictures to assist your explanation, presuming the horizon is presented the same way. Looks like you might have gotten one of the original lenses that were changed to eliminate that. The CGO3+ does not provide a curved horizon.
As well as my H480 I also regularly fly a Phantom 2 Vision Plus which does display a significantly curved horizon. When I feel the need to correct that distortion I generally use a program called 'ProDrenalin' which, incidentally, has a pre-set for the P2V+, and other pre-sets can be made to cover for cameras not already listed in it's stock pre-sets. It works well in removing fisheye but the downside is that once you render the corrected results you lose some of the quality. I also have 'Filmora' which also has a tool for dealing with these distortions but I've never used that tool so I can't comment on how well it works.That sound good for the images but how about the video. Would any program straighten out the video.
Uhhh, no, it doesn't work like that.
So guess I don't the have a problem unless the horizon is stil looking bent in the middle of the screen. Did 2 print screens below. With the one with more sky, not sure if tilt is up all the way but probably most of the way. But still shows some curve. The other with it tilted is more noticeable.
I know I saved pics to jpeg but they converted to png. Didn't have time this morning had to email them to myself to get them on my phone.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
