- Joined
- Dec 16, 2024
- Messages
- 517
- Reaction score
- 264
- Age
- 38
" the second picture shows the connector I’m referring to. I’m not certain is the connection on the gimble board also different making a swap not possible."
The ribbon in the second picture seems to have two rows of connectors, 12 connectors on each side. I would at least count the connectors on each gimbal board to see if they match in numbers. Note this connector does NOT go to either the gimbal board or the Wi-Fi board. This is the connector between the two sections of the Main Ribbon. (The front section is often called the "camera ribbon", the "front main ribbon" or the "Spiral ribbon" I'm not sure why you are looking at this one.
I used a microscope and a multimeter to look for conductor(s) running directly from gimbal board to WiFi Board. It appears there is only one, and that one connects to multiple points on both the gimbal board and the Wi-Fi Board. One would assume it is a ground.
If that assumption is correct, then the Wi-Fi power is back fed from the camera. That would increase the suspicion the issue is a damaged section (or both sections) of the main cable.
