Firstly thanks
@Ty Pilot for confirming firmware dates.
I have backed up the H Plus downloaded firmware so should I need to reinstall it in theory can be done. I will try this out after the next update overwrites the current one.
Here’s what I did.
Plug in the st16s to a pc and navigate to Yuneec OTA folder, open it and you will see current downloaded files, save these into a folder on pc.
Now in theory should you need to replace updated firmware it’s a simple drag and drop to downgrade.
I was speaking to Haydn earlier and he screwed his H+ up because he does like to tinker.
He restored back using this method.
On another note he is showing there is an update build 722 20180706 I am not seeing this or cannot find release notes.
