Gimbal points sideways when forward camera lock switched on?
Hi all. :)
I'm having a problem with my camera Gimbal after a fly-away the other day caused my H to crash into a fence (I see some of you have had similar issues with fly-aways since the last software update too! :(
Anywhoo - When I flick the top left switch from G to F to lock it forward facing, the camera spins and points straight to the right (as you're looking at the back of the drone), instead of spinning to point forwards...
Does anyone know how to reset the forward camera position please?
Thanks! :)
K1 is your Gimbal Pan Conrtol left upper side
ah yes i see what you mean. The pan mode switch is in the fully up mode - pointing at "f"
Am in the hardware monitor screen - i see what you mean by K1 - sorry i got confused! :)
K1 is labeled as the pan control dial, which is pointing at "12 o'clock"
pan mode switch"S2" is in the upper position (F)
tilt mode "S1" is in the upper position (A)
I'm about to try a gimbal calibration
Reactions: wedbster
OK, when you still have the problem, you have the option to calibrate your Gimbal.
Tab on GPS Calibration look for Gimbal Calibration and start it
Got it thanks :)
Part way through calibration now...
Jakebutler
