Gimbal
hi guys another question when you do the calibration gimbal and accelerometer can this only be done once !! Because when try to do it again nothing seems to happen can you advice !!
You can calibrate as often or as many times as you want. When calibrating the gimbal the aircraft should be sitting on the floor, not moving. The gimbal will go through a series of movements when calibrating. Don't touch any of the controls while this process is taking place. Be sure to remove the gimbal lock before turning on the H, and be absolutely certain it has been removed prior to calibrating.
sakshijah
