- Joined
- Aug 19, 2017
- Messages
- 1,851
- Reaction score
- 730
It has already been mentioned in some other post, but I think that batteries are very important to gather all the information together.
The batteries of the H520 are new and differ slightly from those of TH as can be seen in the first picture.
While the TH used LIPO batteries (maximum charge per cell 4.2V), the H520 uses LIHV (Lithium Polymer High Voltage) batteries and allows a maximum charge per cell of 4.35V.
The Typhoon H batteries run on the H520. As it has a lower load capacity, the flight autonomy decreases.
At full load, the battery reaches 17.4V. against the 16.8V that reach the Thypoon H batteries.
LIHV batteries must be charged with a battery charger specifically designed for this type of battery to reach their full potential. Charging these batteries with a LIPO charger or in LIPO mode is not a problem or danger, but charging will be lower, a maximum of 16.8V.
Never charge a LIPO battery with an LIHV charger because when the maximum limit per cell is exceeded we overcharge the battery that will explode with the danger that this entails. This is why Yuneec has changed the battery connectors without a doubt.
Thank you for posting the images mates
