Remove the camera from the aircraft. Power it up, the Main LED should rapidly flash blue. Now tilt the aircraft forward 45 degrees and back twice. The Main LED should now be blinking orange. Turn on the ST-16 and once it boots enter System Settings and Bind. If you do not see SR24_xxxxxx in the left column press the Refresh button. Now select the SR24_xxxxxx that appears in the left column and Bind. Back out to the Main screen. The aircraft should now be bound to the ST-16 and the Main LED should be purple when Angle mode is selected.That's who I got my from. I reached out to him directly and told him there were lots hitting the market without cams. The camera I got works fine, but I can't get the drone to connect to the controller. Blue rapid flash, engages camera, then slow red and three beep intervals.
Once you get this far power the aircraft down and attach the camera. Now power up again and see if both the aircraft and camera are bound to the controller.
