Help .You can make factory reset Typhoon H
Hello.
After updates the engines do not light
The button of ignition Start does not work
I installed updates Americans and not the European ones
How can I fix the problem
Thanks so much.
Hello.
Thanks so much.
Do you live in the USA? If Not I would try and install the correct updates.
[Quote = "pinodrone, Posta: 41711, Membro: 4363"] Già Fatto [/ quote]
[Quote = "Brian Mackey, posta: 41713, membro: 4105"] Non si vive negli Stati Uniti? Se non vorrei provare e installare gli aggiornamenti corretti. [/ Quote]
the correct updates will not let me install it gives me error
I live in Italy
[Quote = "THoff, posta: 41718, membro: 3205"] Che cosa non funziona? La rilegatura, o armare i motori? Forse si aggiorna SIA L'ST16 e il Typhoon H con il firmware americano, dei O Solo Uno Due? [/ Citazione]
arming the motors , only one of the two, Firmware Typhoon H
Typhoon H firmware and America AND NOT LEAVE ME THE EUROPEAN UPDATE
there are two updates you have to do, one for the Typhhon H and then one for the St16 sounds like you only did one
Before sending it in, I would try to do the firmware update via the Yuneec GUI application. Connect the Typhoon H to a Windows computer using a USB cable, it should then show up in the GUI. From there you can click on Firmware Update and select the American Typhoon H firmware file and upload it to the drone.
Great idea!
Pinodrone, you do not need to send it back..
To reset the st-16 back to factory...
click on tablet screen
click on settings
click backup & restore
you should find the option to reset your ST-16 back to factory settings.
once you have done so you will need to rebind the drone and camera also then calibrate the gyro & speed controller.
the Yunnec uk website and EU software firmware.
Firmware
lahorelaptop
