HPlus battery life
More reasons to disconnect the RealSense plug. Only the operator is responsible for assuring the aircraft is safe for flight and your experiments are indicating it may not be when RealSense is connected.
Yuneec’s warranty does not cover “consequential” damages. Those are on you.
buzzing from real sense could be the noise from the fan running in it. but that's only sense if the make of it like the one on the h480 unit. oh if it does have a fan in the rs module check to see that no longer running.
The fan runs regardless of anything else on the RS module, I have not physically disconnected it. The buzzing does have a tonal relationship to the fan speed so might be the cooling fan mosfet going to ground
Pat I did not disconnect the cable, I disabled it in the ST16S menu
But I see your point
tparker1
