Its normal look on YouTube for how to update hplus, at the end of video its the same,it says push update then its says no update.I just checked for updates and it says I need an update, but there is nothing new that I can see. What is strange is that nothing happens when I tap Update.
Does anyone else get this Update notice? Can anyone else download it?
Hi ,dhc you did not say it was a alert , i dont think,you must update twice, once with the controleur, then the second time you must connect the camera to update the drone i think.if you have done that ,then its a bug.if it affects the drone or camera, then i would factory reset the controller, then ask yuneec for the datapilot( ie) the app.you will loss it after the reset.No, it is not normal to get an Update alert when you already have the latest firmware.
My system has never worked correctly, therefore I have nothing to loose by an update, I am welcoming the next one. I still have un-commanded assent issues, and I'm one of the few who's gimbal buzz never got corrected. It is very intermittent and I cannot count my system working correctly at any given time. It has gotten to the point that I'm not using it anymore because of this. I am already "...stuck with unpleasant results" I would welcome any update that fixed my gimbal buzz and the auto ascend issues. Now that Yuneec has introduced the H3, my hopes of an update are diminishing. I wish Yuneec would have completely fixed the Plus before introducing a new one.If your system is working correctly and you are happy with performance you don’t “need” to perform an update. A wise person does not try to fix anything that already works as they need it to.
Now there is a new OTA available, please kindly have a try. Any feedback can share in the board.I just checked for updates and it says I need an update, but there is nothing new that I can see. What is strange is that nothing happens when I tap Update.
ascent issue should be fixed with the new UPDATEI just checked, and an update was waiting. I had my first uncommanded ascent the other day on a job. I've had a 4.7V avionics low power warning...on every flight since new. I'm hoping the update solves some of these problems.
I do not see a new OTA Update available. I have 822/829 installed and it says no update required. I am in the USA and I have had this update for several months, it is not new.Now there is a new OTA available, please kindly have a try. Any feedback can share in the board.
factoryOTA in hidden menuI do not see a new OTA Update available. I have 822/829 installed and it says no update required. I am in the USA and I have had this update for several months, it is not new.
I do not know to access the "Hidden menu".factoryOTA in hidden menu
Okay, I tried build 893 as suggested.
The first thing I learned is it did not fix the gimbal buzz, which I was hoping it would do. Gimbal buzz is still present. I am still waiting.
Second: I do not think it helped the un-commanded ascent issue, but it seemed to change it. I flew about 10 very short flights and I had one flight where the throttle seem to be 200% up and 0% down. It did not ascend by itself like before, and it would hover properly with no input. However it would only ascend violently with the slighted up input and not descend at all with full down input. I was able to still reach it so I hand caught it and emergency stopped the motors. I power-cycled only the aircraft, and it was normal again. Hardware monitor of the ST16S showed that the sticks were operating normally. The rest of the flights were normal.
Third: Flight Control Settings work great! This is the best part of the build. Thank you Yuneec for giving this back to us. The ability to change the Expo curves while flying is even better than the H480. The individual rate sliders for pitch and yaw are also a very nice feature. However the labeling of the "Altitude" slider is misleading to those of us who use Mode 2. "Altitude" needs to be changed to "Pitch" for it to make sense to us who speak English and use Mode 2.
Forth: The slow zoom effect when changing the digital focal length is NOT a welcome feature and NOT a useful feature. It is the WRONG feature! If the C23 could change focal length while recording, then the slow zoom would be very good. But since we have to stop the camera to change magnification, it is wasted time to wait for it to stop zooming before we can record again.
This feature needs to wait until the C23 can record while zooming, then it would be very useful. As it is now, it takes 2.5 seconds to go from 1x to 2x, 5 seconds from 2x to 4x, and about 8 seconds from 4x to 8x. To make matters worse it is also cumulative because it takes almost 8 seconds to go from 1x to 4x and a whopping 15 seconds to do 1x to 8x. This is way too long to wait until we can start recording again. The moment would be lost.
Please bring back the instant zoom until the camera can make use of slow zoom.
LOL! As if it is not bad enough that the menu is hidden, they make the password unavailable. Gotta admit, that is a nice touch. Although in the end it was not difficult to obtain, but I had demonstrate I was worthy of it, then sworn to secrecy with a verbal non-disclosure agreement not to share it with anyone, not even my dog! (so don't even ask!) I'm OK with that because I have something to gain if it fixes my problems. In this case it didn't necessarily fix my problems, but I got control of my Expo curves and rates so it's all good.Concealing critical updates in a “hidden menu” is, bluntly, stupid. There’s nothing that can be said in defense of such practices.
