I’m trying to find out the most recent differences between the 16 and 16S. Would love some feedback if it’s worth upgrading to the S.
Ok. Thanks to both of you for prompt reply!Please be aware the ST16S will not work for any model designed for the ST16. The ST16 will not work for any model drone designed for the ST16S.
The two versions of the ST16 that will work on the Typhoon H and the H920+ are the ST16 and ST16+. The ST16+ is NOT the same as the ST16S.
The ST16+ is the three external antenna version of the ST16.
I am still a little confused. You said "I have a TH Plus", but the picture in your avatar is a Typhoon H Pro. Do you have both?Ok. Thanks to both of you for prompt reply!
I have a TH Plus and a ST16 (3 antennas) so I guess ST16+
Works perfect (beside the latest J1 stick debacle)
If I understand you correctly the ST16S is not an option for me then ?
I ask because the GUI seem much more fun
Sorry. My mistake. It’s a ProI am still a little confused. You said "I have a TH Plus", but the picture in your avatar is a Typhoon H Pro. Do you have both?
So.. the Pro will not work with the ST16S?Sorry. My mistake. It’s a Pro
Ok Thank you. I will just happily keep on flying my PRO with the 16+Unfortunately, no. The ST16S cannot be made to be compatible with the Typhoon H or H Pro. The two controllers are cosmetically very similar, but they have different operating systems and the critical hardware inside is different. The mainboards of each cannot be made to accept the programming from the other.
Да, именно так !подскажите, как получить дополнительную информацию о рейсах?Я думаю, у вас уже есть ST16S. Оба имеют маркировку просто ST16. Самый простой способ подтвердить это - посмотреть на батарею. Батарея ST16 находится под выдвижной дверцей и подключается к контроллеру проводами. Батарея ST16S представляет собой цельный блок, который вставляется в разъемы, встроенные в контроллер.
Или мне нужно что-то обновить?Подскажите, как получить дополнительную информацию о рейсах?
Пожалуйста, помогите нам понять, какой тип информации вам нужен. Я не знаю, нужна ли вам информация о том, как выполнять полетные задания, или вам нужен обзор информации из предыдущего полета.Да, именно так !подскажите, как получить дополнительную информацию о рейсах?
Мне нужна информация о состоянии аккумулятора в полете и посмотреть на карте где коптерПожалуйста, помогите нам понять, какой тип информации вам нужен. Я не знаю, нужна ли вам информация о том, как выполнять полетные задания, или вам нужен обзор информации из предыдущего полета.
Пожалуйста, помогите нам понять, какая информация вам нужна. Я не знаю, нужна ли вам информация о том, как выполнять полетные задания, или вам нужен обзор информации из предыдущего полета.
как мне увидеть такую картинку?
