Is this a first, cgo3
I have a cgo3 that fell off the craft and after connecting the white wire from the craft to the camera the screen is showing everything upside down. I moved it in place and it ain't right. Weird
Ps it was barely off the ground and I try to remember to check it each time. Ideas
Does the camera sit in the frame normally?
Does the camera gimbal tilt up and down as normal?
And yes, this is a new one on me.
The white wire for the Q500 4K plugs in from the battery compartment to a laptop or pc, for using the GUI software to change the settings of the drone plus fault diagnostics.
The CGO3 has a black 3 core wire with white plugs either end in the accessories as a back up if the contact connection on top fails or it has a minor crash and the top plate comes away.
T
Thanks I know that but that's not the problem. I have a good one on now and someone has offered to fix it. Thanx
Get out your phone and take a video of her hands while she is doing that. I’m sure all of us would like to know how she does it.
She did one yesterday in 2 minutes and i am taking baby steps.
Is that for all four dampeners? You must be landing hard for her to get that much practice.
No, if that was the case i would have her to house call. Russ the guy at the late kav did one in his fingers in seconds. I saw this and he had done it so many times that it was 2cd nature. I guess i am not the only ones who need this practice
Well I am slowly getting info and it's not much but she's good at it. She doesn't use dental floss and when I am out of the dog house i will get more info. but apparently there isn't much of a difference from other videos. She will make a video hopefully soon.
Reactions: Tazmanic
Robertwc
