I tested it on the table with the engines off. When the drone is in the air it is impossible to tell if the gimbal is buzzing because of the noise.Was this with the drone on or off, motors running or not? Not flying though.
I'm sending the drone to Germany today. Since it just returned from there they promised to repair it with the highest priority.This is definitely a vibration issue in the gimbal itself.
And it looks a lot like the buzzing issue that where introduced in one of the first updates yuneec sent out.
I had my camera shipped to yuneec for calibration and back then the issue was fixed by yuneec Germany.
I'm assuming that you have checked the rubber dampers for damage and also checked that the gimbal moves freely without obstruction on all tree axis?
Finally, it's the 4th shipment, so the first 3 people were incompetent ...I'm sending the drone to Germany today. Since it just returned from there they promised to repair it with the highest priority.
I would like to ask experts to comment on this vibration. What could have caused it?
What do you mean by overloaded gimble, I'm not sure what that is?In my opinion, this is caused by either an unbalanced prop, a bad motor shaking on a specific rpm or an overloaded gimbal.
ND8 filter weight with the ring was 7.4 grams, the counterweight was 4.4 grams.
"unbalanced prop", "bad motor shaking on a specific rpm" - How can I check these versions?
I didn't notice any differences.A bad motor is worse, but if you spin them with your fingers do all feel the same?
Then it sounds like a issue with one of motors. Have you checked the propeller mounts if one are loose?In a static flight no problems arose. These vibrations not present constantly and appear periodically.
The props are sitting very tightly. If you hold the motor and try to turn the propeller, you can feel a barely noticeable backlash.Then it sounds like a issue with one of motors. Have you checked the propeller mounts if one are loose?
Yes. I'll post a slightly longer video.No wind wouldn't do that, at least in all my 4,500+ minutes of flying.
Is this intermittent?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
