"Jello effect" video
There were no hard landings or crashes. Nothing like that.
Three of the four files have FPS 29.97.
159C23HD - Google Drive
YUN_0001 - 4K(4096x2160)/29.97
YUN_0002 - 2.7K(2720x1536)/29.97
YUN_0003 - Full HD (1920x1080)/29.97
YUN_0004 - 4K(4096x2160)/59.94
I notice you are moving very fast, was this in sport mode?
Also as I mentioned you're not having issues going backwards.
Now I want you to fly very slow. at 30fps
If you stand still or move very slow, there is no vibration. However, if you move a little faster than very slow, the vibrations appear regardless of the frame rate.
The reason I ask if your moving fast, you first flew forward your blades came into view, that usually indicates full speed even in normal mode.
When you were moving backwards it was much slower and all was fine.
My last thought since I'm out of ideas, you have a blade out of wack or even a motor vibrating. Check all your screws where the motor mounts to the arms.
You'll see these screws when you take the blades off.
I have the same problem, but only when the camera is facing 1/3 of the horizon (about 60-65 degrees). In other positions, everything is ok. Did you manage to solve the problem somehow?
tunneyinspectionservices
