The legs will stay in tight and make contact with the mounting screws removed. This is a good thing for your testing. Once you’ve got the ST booted, start your H with no props or camera mounted and wait for connection. Pick the H up and hold it upside down. Cycle the gear switch. If it’s broken parts (bent shaft) the motor will struggle some. If it’s not moving at all then it’s electrical issues or the motor did die. With the power still on and drone still inverted, swap the gear to the opposite sides and try again. If it’s the motor or circuitry, the problem will follow. The motor power card is the little daughter card in mounted behind the main esc board. It’s possible the molex lead popped out. You may need to trace down some voltages from board in to power leads at internal contacts.
