Latest firmware (July 2016) Unofficial Changelog
Trying to collate information spread across numerous threads
Changes:
  • Ability to playback video and photos on ST16
  • Task functions can now be used without enabling advanced mode
  • Ability to enable Realsense module if installed
  • Improved wifi/video connection times
  • GPS can be turned off in flight
  • ST16 battery percentage now shown in top right corner
  • Greater EXIF data including GPS coords in photos
  • New flightlog app in 'pad'
  • Format camera SD card from ST16
  • Improved 1080p 120fps video
Anyone noticed any others?
All in all I think that is quite a significant update. I'm pleased. Lets hope there is more to come!
Changes:
  • Improved wifi connection times
  • Battery percentage now shown in top right corner
  • Format SD card in ST16
The battery percentage is not the H percentage, is the ST16 percentage
and no RTH height setting
Does anyone have any footage of this 1920x1080/120fps video improvement after the firmware update?? I would like to see the change in this from the old to the new.
Changes:
I wish they had a percentage on the battery instead of this voltage amount. Most drones say %50, %30, or even %25 and then you know its time to come home. I am not a fan of the voltage amount.
They scaled the GUI on the ST16. The GUI was slightly smaller before. Sadly this is not an improvement for me.
Reactions: gregreh
At least they are not giving it in US or UK imperial measurements, 153/198, 839/1800, 2987/5876, 20/83
Reactions: Samuel Fowler
Advanced Mode - off, now allows smart routes CCC etc to work.
What we need is a bug list of things that are now broken.
Camera connects faster but appears to disconnects more often.
When the low voltage alarm goes off on the ST16 the 5min video segment being recorded at that moment seems not to get saved to the card. (need to double check but I'm almost sure it's happening).
I haven't flown yet since update but I've read that video lag is less after update but that's unconfirmed Also have you noticed H fits into the case a little better after update?
Reactions: Kahuken and Brent D
Jesster0430
