- Joined
- Sep 19, 2016
- Messages
- 24
- Reaction score
- 11
- Age
- 56
Sounds very interesting, tons of cool features. A pleasure to see Yuneec is still working hard on the H !
Yes!
- Dual Band Control Redundancy
- OTA Upgrade
- Panorama
- New Camera Features(Burst, Timelapse, Histogram, Metering...)
And by looking at that, I am not sure how all this possible without upgrading ST16 and yet I don't see they released new firmware for ST16.
So is the update available? It still says 9/26/2016 for the date released.Good to see movement in the firmware development. Check it out, early adapters, and let's hear about it.
Drone Ver. 3.0 : Gimbal 1.25 - Autopilot 1.29 - Camera 3.2.24 Apparently forgot to change the release date.![]()
Note that the ST-16 firmware is NOT updated at this time.
Well, that sounds strange and depends on the reason control is lost, because when link is lost on 2.4GHz, on 5.8GHz is probably gone from longtime already.Dual Band Control Redundancy:
When the 2.4G signal is lost, users can control the aircraft through 5.8G Wifi as redundancy
That's one reason because video is usually on a shorter wave length: when video degrades there is still full control and it's time to come back.
Ric
I am leveling H on the floor with level tool. I put flat panel on the floor and with level tool set it to be as level as possible. The same procedure every time. But like I wrote before with 2.25 firmware it was drifting but not drifting like you mean. When you move stick forward it will go slightly lef or right and after you go for hard stop it will do drifting circles before stabilize. That is what I mean drifting. So after i tried everything , calibrating this calibrating that dozen time and reinstalling firmware, finaly I decided to revert back to firmware 2.21 as this was firmware that was fine for me. And now after 6 flights all is well. Hopefuly will be with this new firmware. If not , don't really no what to do except send it back to service.I have always said that if the H does not know that it level or is not level it will drift.
