Rebuild Breeze
yes I have a breeze and I would like to know does anyone know can you hotwire straight wire the mot
  • 8
    Votes: 0 0.0%
  • 8
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Hello does any one know if or how you can straight wire a breeze motor? I tried the same I've always done but it will not run the breeze motor!
The motors are not DC or AC, they are run off of a varying DC pulse. They require the output generated by an Electronic Speed Control (ESC).
As Doom states, ESC’s run at some frequency, like 8khz (or other). These timed pulses of varying pulse width control how fast the motor turns. The timing is critical for the motor to run properly and varies based on the number of poles in the motor.
In other RC applications there are many programmable settings for ESC’s. The Breeze (Yuneec) has already set these parameters for you. I’m not aware you can chance them.
As a side note, ESC’s have current ratings (limits) like 5,10,15 ... amps. The motor load needs to be controlled closely so you don’t exceed these ESC limits, else the ESC ‘blows’ (you’ll see smoke).
I suggest you read up in ESC’s on the internet before you try things like this.
Here’s a good video to start! PWM
jonnyelectric
