- Joined
- Dec 16, 2024
- Messages
- 508
- Reaction score
- 256
- Age
- 38
In my experience the greyed out WiFi was due to a burnt out WiFi module on several occasions. U said u replaced the 2.4ghz board ? Is this correct, the WiFi board is the 5ghz board as pictured above . Even with the drone powered off the WiFi should toggle on in the android menu and show other WiFi connections like home WiFi. That is provided the module is not burt out.I replaced the 2.4 GHz board. Was this the correct component to repalce or do i need to replace the 5 + ghz board?
On that note has anyone determined what actually burns out on the WiFi module??? Perhaps I’ll need to remove the antenna and look with a thermal camera to see what heats up and burns out
