Typhoon H camera problem
I'd check the video signal wire that runs from the slip ring up to the gimbal mount, and the gimbal-to-drone contacts.
I inspected the wires around the slip ring. I reseated the base connector. That seemed to work. I have another camera to use and work to do with it so I couldn't get to it quickly. I'll get a replacement slip ring motor just in case the problem returns and replace it later.
Polenutrition
