Typhoon h plus issue with rth
Tap the circle with the 6 dots at the bottom of the screen, then look for a black "Yuneec" icon that says "FlightMode2.0" under it.
There is no flightmode 2.0 that’s what I’m trying to say. After factory reset there’s nothing
Phase 2 of the instructions puts the APP (FlightMode2.0) back on your controller. Did you do Step 6 of the preparations section at the front of the document to allow "unknown sources"?
So when you started the controller with the SD card inserted, it just did a normal start-up and ended on the green APP screen?
So Phase 2 worked. Good Job. Now let's start on Phase 3.
Does the disk have:
A folder named "TX"
A folder named "firmware"
A file named "Update.zip" ?
Does the disk have:
A folder named "TX"
Yes
Does the disk have:
A folder named "TX"
yes but it’s not working?I’ll keep trying maybe I’m doing it wrong
You need all three things listed.
TX folder and its contents
Firmware folder and it’s contents
And the update.zip file
mikedh
