Explain more. Are you hitting RTH when it is a distance away, or are you doing it when it just takes off or is already above you?When I hit the return to home on the st16s the drone just flies straight up into space. And I noticed I have no speed reading on remote but it’s moving really fast?
Doesn’t matter I tried at 100 meters away and it flies straight up way pass 300 meters high and just keeps going until you turn off the RTH then it just hovers and you have to manually fly backExplain more. Are you hitting RTH when it is a distance away, or are you doing it when it just takes off or is already above you?
Ok purchased drone off eBay and this is what you get I guess ?lesson learned don’t buy Used or refurbished drones. It flies nice and stable but doesn’t have any speed readings on remote just distance and height and when you try using the RTH function it literally just flies straight up and won’t stop until you cancel the RTH I’m dumbfounded. I own a h480 and a H920 and the RTH ALWAYS COMES TO YOU!Doesn’t matter I tried at 100 meters away and it flies straight up way pass 300 meters high and just keeps going until you turn off the RTH then it just hovers and you have to manually fly back
I don’t have a camera and don’t use the drone for photography. Only use drone for carrying out fishing baits at night so camera is useless anyway. Was just wondering if anyone would try flying your drone a few hundred meters away and see if your RTH function still works without camera would really help me out. Because if it needs the camera for RTH function to work will just give it to a friend who might be willing to buy a cameraJust tried removing the camera while the drone was bound. The Return To Home setpoint changed from the actual setting to "0" feet. Returned to normal when I put the camera back on. Not sure if that has any bearing on what you saw, but were you flying without a camera, by any chance?
Also, apologies to any who read the misleading information originally provided in this post. That part of the post has been edited out.
You used the term "hplus/520". It is important which one. The H520 has a binding process on another page made especially for binding without a camera. Please clarify which we are working with.I own all three Yuneec drones h480, hplus/520 and H920. Both the 480 and 920 fly perfect without cameras and the RTH works flawlessly. But the 520/plus doesn’t work at all and NO I don’t have a camera and yes I was flying with no camera because I don’t have one the one that came with the drone was smashed like it fell off during flight and seller lied about it.
"Was just wondering if anyone would try flying your drone a few hundred meters away and see if your RTH function still works without camera would really help me out."I don’t have a camera and don’t use the drone for photography. Only use drone for carrying out fishing baits at night so camera is useless anyway. Was just wondering if anyone would try flying your drone a few hundred meters away and see if your RTH function still works without camera would really help me out. Because if it needs the camera for RTH function to work will just give it to a friend who might be willing to buy a camera
Sorry don’t really understand what you’re talking about so I can’t take a pictureI believe @davemh can answer that question about RTH with no camera on the H+.
It would really help if you would post a screen shot of the firmware update screen while bound to the aircraft as suggested by @WTFDproject. If versions are matched I would suggest doing a factory reset on the controller.
What are you talking about? If what firmware matches? Controller and drone? It flys fine no problems at all just no RTH and no speed readings. And I do not have a cameraI believe @davemh can answer that question about RTH with no camera on the H+.
H plusYou used the term "hplus/520". It is important which one. The H520 has a binding process on another page made especially for binding without a camera. Please clarify which we are working with.
How?"Was just wondering if anyone would try flying your drone a few hundred meters away and see if your RTH function still works without camera would really help me out."
I'm not in a good location for distance flights, but I did do a couple brief flights. Both were only about 75 feet up. One was straight up, the other was same altitude, and about 40 yards out. Both without camera, of course. BOTH FLIGHTS WERE WITH AN HPLUS AND AN HPLUS ST16S. In both these cases, the RTL worked normally. The drone came back/descended, lowered it's landing gear, and landed as expected. I would need to do more flights at greater heights and distance to evaluate exactly what the machine is using for RTH height (I suspect it is using the 65 ft default), but these initial results suggest the absence of camera is NOT the issue. At least not if you are working with an HPlus and it's intended controller.
That leads us back to evaluating your firmware as the next logical step, and getting clarification of which drone/controller you are using.
