typhoon h plus wont connect to wifi
Looks like it should be working.
Go to Internal storage, then look under "Yuneec OTA" and see if any files are stored there. I'm not sure we can get around the system not initiating the reload from SD card, but let's at least see what resources might be available.\
Never Mind.
update went good still no fix on wifi.....
Did you:
Did you check the on/off slider in android settings?
Turn the drone upside down to initiate bind mode (ALL motor LEDs flashing greenish yellow)?
Click the "refresh" icon on the WiFi Bind screen for both Drone and Camera?
Also, did you:
Yeah I tried that. I ended up exchanging it for a new one. Thanks for the help!
Have you tried turning off your WIFI router! This might force the Tranni to find your H?
patkiivf22
