Typhoon H won't fly more than 120 meters, OBS is not available
Everything was fine until i stopped flying drone for like couple of months, yesterday i wanted to fly but drone dont want to fly more than 120 meters in any direction, it just stops, OBS is also not available. I did read about updates making this problem but i dont really remember doing one. Typhoon H and ST16
The 120 meters issue sounds like you are flying in "Smart Mode" and have a GEO Fence set via the GUI. If so, either move the Flight Mode Switch to the center (Angle Mode) or connect to the GUI and remove the Geo Fence.
The OBS not available warning should stop when the aircraft reaches a few meters off the ground. You can clear the warning temporarily by tapping the return symbol below the lower right of the screen.
i did it and it works, but does it reset after turn off? I connected drone to pc and default values were set again. I tried turning OBS on while being 30 meters in the air but it doesnt work, still not available
Were you seeing the default value re-appear under the "Current Value" or in the "New Value" box?
The Geo Fence "New Value" resets to default each time you restart the GUI. But it should not change the value on the drone (Current Value) unless you press the "Update" button.
I am the wrong person to discuss RealSense and OBS. I do not use either and the two systems have too many oddities for me to attempt diagnosis.
OBS may be defective, this hard to diagnose from farMy first attempt would be to create an complete new clean model and bind the drone/camera to the new model. Try again. New model has no influence on geofence. But I found that some flight controller lost the values and set it back to default after long storage without powering on. In this case you need it set again with GUI. After that it should be stored for a long time (but it looks not forever :rolleyes:).
Reactions: WTFDproject
I remember not paying attention at times forgetting to check angle mode and smart mode. Definitely a big duh on my part. I hope that's at least part of the problem.
Hello !
"If I have not misunderstood, the problem is that it does not exceed 120 meters in height?
Since if this is the case, by setting the altitude to 0, the Typhoon H goes up to 400 meters !
Kkit
