Has a 107 pilot I'm suppose to keep my H current with all updates, but it's rock solid even in high winds. If I'm sitting still my video looks like I'm locked down on a tripod. everything works great. So do I upgrade or not?
I did it today. Took me a couple of hours but no glitches and flew 2 batteries just fine.This 2-24-17 upgrade appears to be rock solid, so if you are comfortable doing upgrades, go for it. if you have problems doing upgrades, pass on by. it only gives you the ability to change your max height, and adds more stability when landing.
I'm Part 107, but no update until Zoom on camera or heading info on screen.Has a 107 pilot I'm suppose to keep my H current with all updates, but it's rock solid even in high winds. If I'm sitting still my video looks like I'm locked down on a tripod. everything works great. So do I upgrade or not?
I can only speak as a U.K. Civil Aviation Authority Commercial Operations Permission Holder which, I believe, is roughly comparable to 107.Has a 107 pilot I'm suppose to keep my H current with all updates, but it's rock solid even in high winds. If I'm sitting still my video looks like I'm locked down on a tripod. everything works great. So do I upgrade or not?
I agree with this. Definitely use your best judgment as remote pic to determine if you need to do the fw update.As a 107 operator it is your responsibility to assure the aircraft is safe for flight. Since firmware is an integral part of the aircraft operating system it becomes your responsibility to assure new firmware functions correctly prior to incorporating it into the operating system. In my view a 107 operator is fully justified in delaying firmware upgrades until it is established as safe and functional.
Something I find of interest is the habit of all the manufacturers in releasing firmware that has not been fully vetted. Since the manufacturers know they are providing firmware to commercial operators it won't be surprising to see the FAA or DOT start holding them legally liable for public harm induced by defective firmware. The public beta testing of new firmware needs to come to an end.
There you go.
I don't like OTA, so I just use a card, put both update files on it and do the ST16, then rebind, switch card to the Camera, and do the drone. Piece of cake.
Very good information. I have had very little issues with my H and all of the updates have gone well. Im one of those guys...yeah I know.I think in regard to your 107 if you are happy with the operation of the craft leave you would be ok to leave it as is until you decide to upgrade.
As all these drone reg tends to follow/come from fullsize aircraft airworthiness regulations, the way it works is (with my fullsize aircraft inspectors hat on) if a document issued by the manufacturer is classed as mandatory then the upgrade/change must be completed before the next flight, if it is classed as an advisory notice then it is generally considered to be upto the owner when to implement, but to monitor the situation in the mean time.
If Yuneec stated this firmware update must be done by all owners due to a fault/glitch etc, then to comply to your 107 you would have to do it.
As it is just an upgrade then you would not be bound to do it in aviation law until you felt it was in your interest or you discovered a need.
