Velcro to hold battery, just in case!
I wanted to post this for those of you wanting extra measure so your battery won't dislodge.
Not sure how far out the battery needs to come loose before it's disengaged from the pins and power is lost?20180915_170049.jpg20180915_170221.jpg
Used clear Gorilla glue, Velcro glued to the H then gorilla taped over.
Left Gorilla tape on for extra measure.
I think once you put this on, you really take a double look to make sure your battery is secured.
You may want to apply this to your safety log check list
Good solution... just for general information... there will need to be some modification for a model with RS installed. Your tape on the undercarriage would cover the downward facing IPS sensors.
Just install the Velcro side to side instead of top to bottom. The same security feature works for retaining a same capacity or larger after market lipo should to elect to route power wires out the bottom of the aircraft. Nice thing about Yuneec aircraft, once you buy the first battery to have the plug you’ll need to adapt standard lipos.
Ludwig
