I hope they "tuned your gimbal" for you.Gear, GPS, compass, boom, half shell, updated firmware, checked camera, test flew, removed their flight props and kept them, packaged loosely for the return trip.
Update:: 2/9/18 Finally got threw to talk to someone, according to the logs GPS Failed had to send drone back to them..I don't know? Ordered 1/1/18, received 1/23/18, worked for 2 days, 3rd day it went on and weird orbit buy itself and was unresponsive then crashed, 1/29/18 called and sent in log haven't heard from since other than " make take 5 to 7 days".
I am thinking i may have made a mistake buying this thing I mean dollar for dollar i could have rented a helicopter and got the 3 videos and 5 pics. the worse part is i haven't even got to send it back to them yet, so i still have a month or two. maybe i should just go for a refund...
You might want to go to this link and download the manual for your Typhoon H.
Typhoon H manual - cleaned Up and updated (70pgs)
If you have RealSense enabled in the ST16 Settings it won't land with the landing gear up. I'm hoping that you performed all the calibrations again before flying (accelerometer, compass, gimbal)
Thanks for that but, I have read the updated manual. I have had the H over a year and know how to operate it. I know you can't land with the Intelsense On.(Props off on the ground) I had it on in the video because I wanted to troubleshoot from a list the techs sent me and suggestions in here. I'm sorry I should have provided more details on what I was doing to troubleshoot.
The problem with my H is NOT landing. It doesn't respond to stick down command over 100 feet. Having Intelsense activated should not have anything to do with changing altitudes. I never use it anyway for the flying I do. I hand catch it also 100 % of the time so it never touches the ground with motors running.
Kavservice has sent me an RA# today and they believe the Intelsense module is bad. So I guess they think it is interfering with the manual (angle) control of the H even when it's turned off.
1. Won't respond to left stick down above 100 feet (Intelsense off)
2. Will only descend about 100 feet when landing gear is manually lowered.
3. Once below 100 feet descent control is restored (gear up or down) with Intelsense on or off.
Dang,
What do you mean by RealSense "on"? If you've enabled RealSense in the ST16 settings it will always be on. Are you turning on "Obstacle Avoidance"?
Are you flying line of sight? If so, and you're 2 blocks away with unobstructed view of the aircraft it shouldn't drop video unless you're near power lines, large metal structures, etc.
One side effect of RealSense is that it will NOT allow you to land with the landing gear up.
When you mention “choppy video” are you referring to what’s on the St-16 or the video card? The video you want is on the card, not the -16, and formatting the card does nothing for the -16 video...
