So I was helping someone set up a Typhoon H and in the past, there haven't been anything too outstanding about them as I usually prefer to use DJI. It was fresh out of the box and as we tried to set it up, we noticed that the light on the camera wasn't lighting up at all. I know that it has to blink in order to transmit image to the controller but that wasn't happening in this case. We made sure to put in the SD card into the camera but we couldn't get past that step. I might not be the best at explaining but I will include everything that we know and did.
Now my question is, how do we make it connect? I did try looking at other forums but nothing is working. We did try binding it and we almost got somewhere but after a few minutes of waiting to see if it would set up or bind, the code for the camera said 'Not Connected'. We did have movement but after that occurred, we had no control what so ever and it's left me more baffled. I'm not sure if anyone has run into this issue before but we don't know what to do at this point.
We're also having internet problems as we want to see if maybe we need an update but even so, it did say first that the aircraft wasn't detected and then continued on to say that the camera was not compatible.
I hope someone knows something as this was also tried on another drone and it was experiencing the same issue. I'm no expert on Typhoons so I apologize for the bad explanation but hope someone can help!
