Hey folks...Happy Holidays To Everyone!
I recently upgraded the firmware to the latest (had not done it since September), so I'm just wrapping my head around the new features.
My question is on the Cruise Control using the D-Pad. Is it just me, or does the H only change direction when you rotate the craft somewhere in the 45 degree range? To further explain my question...here's what I'm doing:
1. Launching the H as normal (I recently re calibrated everything so it's all good)
2. I press the right D-Pad "UP" about 4 times to get the H moving forward
3. I then use the left stick on the controller to start turning the H and pointing it say +10 degrees
At this point I would expect the H to start flying in the direction that it's pointing...instead it just keeps moving forward in the original direction
It's only when I make more aggressive turns (it feels like 40-45 degrees), before it seems to respond and start flying in that direction.
Is this as expected, or do I have something set wrong?
Apologies is this question has already been asked, but I did a cursory search on the forum and didn't see it.
Thanks in advance for any help!
