Gear issues
Greenwood Village Colorado
Greetings fellow pilots way smarter than I , recently put my H+ back together, surprisingly it flys beautifully one exception the right landing gear will not retract, checked connection installed a new leg I’m stymied any ideas?
Need some help understanding your issue:
1.) Have you turned the HPlus upside down, and given a "bump" to the stuck gear?
2.) Does Left landing gear move full travel?
3.) Have you moved the Right landing gear to the Left side to see if it will operate?
4.) Have you moved the Left landing gear to the Right side to see if it will operate?
Reactions: DoomMeister
WOW the left smoothly retracts however I have not tried any of the recommendations and tomorrow I shall. Thanks as usual
Scott
You can remove and test the gear to make sure it is working. See the end of this video at min 9:38.
rubikonsgd
