- Joined
- Mar 20, 2018
- Messages
- 123
- Reaction score
- 51
- Age
- 81
The date on my sd card photos is incorrect. Shows 2013. How do you reset to current date. Manual is silent on this.
Time date was off by one hour. Reset and took a couple photos using same sd card. Time and date now read correctly. Not sure what happened, but seems ok now.Note: moved this thread to H+ forum.
When you connect to the home network you will have the correct date and time. When flying and daylight savings is in effect you will be an hour behind. GPS is used for time while flying and the satellites do not use daylight savings. They run on atomic clocks, not our goofed up system of time keeping.Time date was off by one hour. Reset and took a couple photos using same sd card. Time and date now read correctly. Not sure what happened, but seems ok now.
Thank you.
Ok. I can live with one hour difference but it was showing 2012. Kinda funky. Seems ok now. Thank you for your help.When you connect to the home network you will have the correct date and time. When flying and daylight savings is in effect you will be an hour behind. GPS is used for time while flying and the satellites do not use daylight savings. They run on atomic clocks, not our goofed up system of time keeping.
