I have prepared two missions at the same place.
1) A circular mission with the H520 pointed at the central point.
2) The same mission with the H520 following the circle with the camera yam directed to the central point.
Both missions are a disaster.
Mission 1, the H520 does the circular but without pointing to the center.
Mission 2, the H520 points the camera well in the center but does not stay on the center and refocuses only on the next piont and so on.
But what is most painful and incomprehensible with respect to the H and DJI Inspire is that
it is unable to manage a curved trajectory between two points.
At each point he makes a stop, turns and leaves.
What is this about H.
I had to redo the mission with the Inspire so that all the video is fluid.
It is impossible to launch a fluid mission, it is incredible for a device that is worth three times more expensive than his little brother (who does it).
Do you have a solution or should I leave the H520 in the closet?
At point 4 the camera is centered in the middle but remains fixed until point 6.
At point 6 refocuses in the middle and remains fixed until point 8 etc ...
It's a gag?
It's a gag?
