H520 - CGO ET Camera
UK
Recently purchased this camera (used) but very good condition. Bind with St16 and performed firmware updates and successfuly flashed to camera. Problem,...the camera will not connect with ST16 when vehicle is turn on unless i perform this manual. Anyone experienced this issue before and know how to rectify or is this normal!!
Just a point for validation: the CGO-ET you have is one specifically for the H520, and not for the H480, correct?
Have you ever connected the ST16 to your wifi router? If so you must go to Android settings, select wifi, then select your router and select forget.
Reactions: DoomMeister
terryguindon57
